How hard to change engine loom?
Car  Tweaked Leon Cupra R
e.g. does it run straight from engine to ecu, and is the ecu plug n play so to speak?
Hard if you dont know what your doing, you need to have a good look at it first and do some research, other wise when you ask for help, you wont know what your on about or anyone else for that matter, get a haynes manual
hard work mate gonna have to remove front bumper,bonnet may be the front wheels.all this just for easy acsess.then most of the engine parts will need to be removed i.e injectors,sensors you name it.alot of time and fustration but possible
But i'm planning on doing the engine at same time. Do i have to strip the dash at all or does it just plug into the ecu?
