With the snow foam you can fill the bottle up to a very strong ratio and use the adjuster on the foam lances to regulate the amount of snow foam that is pulled through. If you find yourself emptying the tank to quickly even on a full ratio setting just increase the amount of solution in the tank and knock back the adjuster.
That way you will also not have to fill the tank as often.
Ye as above. You can adjust the amount and how much it spreads. I also find once you fiulled the bottle up, cover the top and give it a quick shake then connet it up. It foams even more!!!
