How much diff will cams actually make?
As above really! Been looking in to getting some awt cams and just wondered what the diff would be like bearing in mind my few other mods?
My spec so far is:-
Straight through exhaust and decat
HP chip
Modded airbox with itg filter
supersprint manifold and a few other bits and pieces....
Think its anywhere from 12 - 20 bhp depending on timing, headwork and ECU mapping to suit.
just so you know, the gains on 1.8's are more than proportionally less than on a 2ltr due to the statistics of the engine's
on the 2ltr F7 they make a huge difference, and if you use the correct profile you wont loost any low down torque, you'll gain it.
Ok sounds good!
So i take it the price you quoted is still ok for the F7R?
Will my car need remapping or wi it just DO of the standard chip for now? Any idea on gains Ben?
yup, the quote stands, its the same work.
It'll be best on a remap, but it'll run quite well on the std ecu.
For gains, i put a large post on williams clio in the tech forum, under 'anyone running awt cams'.
Smokey said:
Do it Tom, Im considering it too :)
Well its either cams or go jap. I like my clio and have nowt but time so i think cams are on the list to be done very very soon! :cool:
Tom....my cams are going in as soon as they arrive,(Sandard map on my car too)Hopefully b4 the trackday,so wait and see how mine runs-then you can decide.
Ben are there decent gains to be found of the 172 block with thr addition of Cams?
gains arent as large as the F7R, and in std trim its restricted by alot, and even then you cant run anything remotely wild on the std ecu due to it basically walking away in a huff if you run any sort of overlap value on the idle strategy...i.e it wont idle at all.
So are these cams made by yourself Ben?
I know of someone with a 16v and may want to consider this.. do they take long also?
Tom
I do not physically make them no, that takes some serious serious investment into CNC grinding machinery lol.
They are ground to my designs though.
Does what take long?
