How much drop wih 17’s
-60 mm 17s et 37 phase 2 mark 1 clio no rubbin anywhere even on full lock with 5 people in it.
i want my back down 80mm but just the back cus the fronts low enuf how can i go about this just the back that is?
Get coil overs, the only way to a real lowering;) Will handle much better too. But with -80mm you will get some rubbing , or your are very very luckey. Mine rubs slight on full lock with nearly -70mm and 17´s, on the bumber not in the arches. it´s a ph 1 (pre´ facelift)
If you wan´t -80mm then go´ for FK my H&R will "only" lower -70mm and they are a bit more expensive.
Quote: Originally posted by NeiLD0wN on 28 April 2004
How much can my mate drop his clio mk2 without any arch work to fit on 17s
-65-70mm dependin on the offset.......but it will rub slight on full lock and over bumbs ect.
