How Much to Put a Clip On a CV Boot?
Car  Add me 2 ur PS3 - Lylak
Hello all,
How much do you think the local garage will charge me to fit and supply the metal clip that goes around the cv boot as at the moment it's held on by a cable tie. It's not losing much grease, so I don't think he'll fill it with any new grease but it needs doing before teh cable tie falls off completely.
I can't imagine it to be too much, but you never know.
Place your bets now...!
I'll end up splurting grease all over the place. It's a messy job and would rather the garage did it.
How much is the clip from Renault?
Gotta clean my alloy wheels as the drivers side went earlier in the year and the grease is a nightmare. It's like I've got black insides to my alloys!
Yeah it's a common fault, if they go then get a universal cv boot with a rubber seal rather than plastic that Renault use as the plastic seal is useless.
afaik you cant buy the clip from renault seperate, only in a cv boot kit but when my car was in to get serviced they just put a jubilee clip on it as he said the standard ones are crap.
rentec were selling these uni kits the other day, i bought one from them about £11 comes with grease boot and all clips.
Fitted a 100mm jubilee clip on my CV boot but when wheel / shaft rotate the tightening clip is rubbing on the strut!
