How reliable is the range left on the trip computer?
I was always under the impression the fuel filter was in the tank on Clio's and a b**ch to change.
I don't really think running a car with little fuel makes any difference to if it was full. The filters will still capture the same s**t lol.
Depends on model. 172 is under and outside fuel tank. 1.2 16v are in the tank!
not sure with clios but with most petrols its under the car. the strainer is in the tank tho. thats on the end of the pump inlet
ph1's deffo have a filter as part of the pump inside the tank. They aren't difficult to change at all. Think ph2's have a slightly different pump without a return pipe.
Drove from Loughborough to Norfolk the other day and saw mine hit 51.2mpg when I arrived cruising at 50 most of the way range was over 500 miles at one point and ended up getting 460 miles to a tank.
All my Ph1s have been out of the car. And that's seven so don't expect them to be the only ones ;)
I'm not saying they don't have another filter somwhere, but that they do have a filter as part of the pump, inside the tank.
On the phase 1's the filters are external, on the phase 2's bar a few early 172's they are all in the tank.
Filter is the same as fitted to an Audi RS6 from memory on the phase 1 172's
The proper filter is under the tank. Ph1 172 fuel pumps are all in the tank?! WTF you on about?
