How soft should stock rear suspension be -182
My 182 has had both its rear struts replaced with Boge Turbos ( which I think is the correct shock ?) recently by its previous owner. However it seems very wallowy in the rear. Without much effort I can move the back of the car up and down very easily through a decent amount of suspension travel. I know there is hardly any weight in the rear of the clio, but is this normal ?
I have checked the shocks for signs of leakage and there appears to be none. I am wanting to move into Eiback Sportlines anyway very soon.
Any thoughts ?
Ahhh...interesting, there is my problem then ! It is under warranty so if they have replaced with the incorrect shock then need to get it sorted. So KYB is what I need. Thanks very much guys.
Have you considered the koni adjustables if you're content on keeping it relatively OEM?
Yes, looking at that option. Koni's with Eibach Sportlines seem like they would be a nice upgrade. I live in NZ, so not as much choice as you chaps enjoy over there but will ask around :-)
