I used the connect 2 kit from MT Audio on here, depending on which gen ipod you get you may also need the converter if you want it to be charged when you use it
I've got one of these: http://cgi.ebay.co.uk/CTARNUSB003-R...248?pt=LH_DefaultDomain_3&hash=item2308b44128 (didn't pay that much though!)
Can't recommend them enough. I don't use an ipod, but if you do you can still scroll through 6 playlists (using you 6 cd changer buttons on the standard stereo) on an ipod, but also has AUX input (3.5), SD and USB. I use a 8gb USB pen with loads of songs on it, you can scroll through etc and just play the music on the USB pen (set into 6 folders).
It plugs into the CD changer port in the back of the stereo, and as I use a USB pen I don't need to charge - but can check with my ipod if you want...
I also prefer this as I don't worry about leaving my ipod in the car, potentially a theft risk...
If you have the Update list radio you can get a simple aux in cable.
doesn't say anywhere it has an ipod cable/connection & doesn't show one in the picture!
It says Update on it.
I can recommend the Dension Kit, just fitted it to mine, very good! The optional cradle fits the iphone 3 and 4 (and charges both) as well as most of the iPod range. If you have sat nave on your ipod/iphone, it fires that through the speakers too, it also has a slot to accommodate a USB device (hard drive/pen drive etc).
G
