H Hobin Car Clio 1.2 Oct 21, 2007 #1 i need to find out the engine code on my m2 ph2 but the sticker from under the bonnet has been removed is there any other way of finding the code out
H Hobin Car Clio 1.2 Oct 21, 2007 #3 Danlp6 said: d7f. Click to expand... isnt there more to an engine code than that
D Dan@SJM Car 07969 124504 Oct 21, 2007 #5 Hobin said: Danlp6 said: d7f. Click to expand... isnt there more to an engine code than that Click to expand... Well it's located on the front of the engine im assuming your after the code to order parts? ifso thats all you'll need.
H Hobin Car Clio 1.2 Oct 22, 2007 #6 nope i getting a full new engine so i need to make sure its correct beacuse i need to replace it with the exact same engine
B BRUN Car Skoda Fabia vRS Oct 23, 2007 #7 ring me @ work tomorrow, 01744 454330 and ill tell you everything you need, as long as you have your reg number handy, ask for Martyn
E edde Oct 25, 2007 #8 The engine code is on the block done by the front of the engine. It will be D7f and 3 digits.
