Last time I posted this there was an issue I'm not sure why n oone has ever explain fully why. I think it was just a safety thing.
Therefore I will include this legal warning.
The written words and pictures shown below are how to install a Renault dilogues. This piece of software is copyright of Renault LTD and so as such this guide is only for use by Renault dealers who may be ghaving problems installing this software.
Anyone who is not a Renault delaership nomintaed user who is using this guide as a source of information on how to install the software should be aware that it is illegal to own this software or sell or trade this and is in viloation of the legal copyright ownership of the software.
When I find the screen dump photes and guide on how to use it I'll print a full guide until then I've posted the writted word here.
Assuming you have the CD's then follow this guide if your downloading the files then see the bottom of the guide for what to do to make the CD's up.
1) Go to ad remove programs and if you have either Adobe Acrobat Reader, Java Runtime or QuickTime remove them. Restart if necessary to compete removal of the programs.
2) Put CD 1 into the machine and browse to D:\languages\installers\ (where D is your CD drive) and run
3) Acrobat Reader Run the ar40eng.exe file
4) Java Runtime Run the j2re-131.exe file
5) QuickTime Run the QuickTimeInstaller.exe file. Follow the instructions until you get to the "choose an installation type" window, you MUST select "custom" then "select all" - continue to install. If it comes up that you have a newer version already installed you must remove that program first, but you should have removed them earlier. (You can always reload the newer version again free from their website I believe but I haven't bothered)
6) Restart your computer
7) Insert dialogys disc 1 and run the file "InstallPC.exe" file and follow the instructions. The installed file is ~2.1 Gig so make sure you have enough free space.
6 Insert dialogys disc 2 when told to.
7) Restart the PC if requested to.
8) If when you install it you cannot find any dialogys link on the desktop or it doesn't work then search for a file called
"dialogys.bat" in the directory you installed the dialogys to. Make a shortcut to this program and leave it on the desktop and run that instead.
How to use the Dialogys.
If you have it installed then when you run the Dialogys.MPF file it should start up. The first screen you should see should look like this.
((((((((((((((((First picture)))))))))))))))))))
Into here you need to install the oval details for your car. The oval plate for MK1 Clio is found on the front suspension strut under the bonnet. For the newer Clio i.e. Mk2 then its located lower down on the drivers door pillar. To understand what it means have a look at the picture below.
(((((((((((((((oval plate picture)))))))))))))))))
Unfortunately unless you can guess getting details on other cars can be difficult. I have this list of codes if there any use
CB1N 172 Cup Also known as the Sport Lightweight Clio
CB0M 172
CB05 Extreme/Dynamic 1.2 16V
CB07 Extreme/Dynamic 1.5 65hp
CB08 Extreme/Dynamic 1.5 80hp
CB0P (Dynamic) 1.4 16V
CB1D (Dynamic) 1.6 16V
CB1A is the Mk 1 V6 Code
CB1H seems to be the Mk2 V6 details
CB22 is the 182 Code I believe but the dialogys don't contain 182 details
Most Clio's are of a spec /5 (its a code showing a high spec).
Then you can click on the icons and it will give you the parts description for you car.
The PR bit takes you to a parts list for your car so if you wanted to buy a new splitter say then there are three ways to do it.
A) Enter into the box the words splitter then search, have a look though the results for the part and double click it (it works on a tree diagram sort of idea)
B) Highlight the appropriate bit i.e. bodywork, then click drawing and search by going though the parts.
C) Go though the tree diagram type search for parts. See picture below
Once the part screen has loaded up click on the part you want to look at and this screen shown below will appear.
((((((((((((((part screen)))))))))))))))))
From here click the number of the part you want to look at i.e. click on the number 9 to see the parts code and price of the part (ex vat) for the part. Don't forget though that there can be multiple images (have a loom at what I've circled in red as if what you see isn't on the first sheet it will probably be on the other ones. This price list isn't up to date as the copy of the dialogys used at the moment is about a year out of date (02/09/2004) but the codes will be the same so you can ring Renault and quote the part number for an accurate price.
The button labelled (((((((RM))))))))) is a repair manual it contains details on how to remove bits from the car correctly and how to replace parts damaged during a crash etc.
The (((((((((NT))))))))) is a part of the dialogys which contains technical notes on the Clio.
Assuming you have downloaded the file from the net and want to burn the CD's off
Stick the downloaded files into separate directories for each CD, each directory should have 1 x bin file and 1 x cue file.
If your using burning the CDs with CDRWin.
Download CDRWin here (((((((http://www.goldenhawk.com/))))))
You should have one .bin and one .cue-file.
CB0M 172
