You need to get under the car and unbolt them from underneath , There is 4 bolts for each seat and once these are undone the seats lift right out . Danny_172 has done it on his clio
disconnect battery, 4 nuts under the floor, outer ones next to the sill have got rubber bungs hiding them. unplug airbag connections under the seat and lift it out.
Underneath the car there are 4 nuts (per seat) at the corners of the runners, then in clip the airbag wire
(2 visible easily and 2 through the heat shield for your mid section)
^that method removes the entire seat including runners
The below method separates the seats from runners >
T20 screw at the rear of the plastic covers for the runner, then a large (T40 IIRC) screw holds the pretensioner on, unplug that, then 4 nuts are visible for the seats to the runners
