4ft long bar over the breaker bar, along with heat applied to the hub nut, be carefull how much heat you apply to the huib nut as you may fry the bearing grease..
Ive been in the same situation before working on a Volvo 850, even with the 4ft pole over the breaker it wouldnt shift, only when heat was applied did it budge....
