Clio 172
				Recently I have had a bad noise coming from my engine and with the other engine probs ontop I have decided it would be easier and cheaper to fit another engine.
I have low milage engine waiting to go into the car but I would like to know what you personally would replace before fitting it back into the car.
Currently changing:
Cambelt
Cambelt tensioner + idler
Water pump
Oil change + engine oil flush
Coolant flush
New fully sem oil
New oil filter
New ht leads
New rotor arm
New dist cap
New aux belt
New powersteering fluid
New brake fluid
I have a bill for a clutch kit replacement (22k) ago so no need for a clutch im guessing
Can you think of anything else I should do?
Oh and old engine had oil dripping from bottom of spark plugs when they we removed what causes this?
Currently changing:
Cambelt
Water pump
Coolant flush
New fully sem oil
New oil filter
New ht leads
New rotor arm
New dist cap
New aux belt
New brake fluid
