Ice Advise
Car  Clio 182 cup
Just bought pioneer deh 7200sd head unit for me cupster!
I have a two block adaptor lead but there is know where to plug the little yellow block?
I have noticed it doesn't store channels after switch engine off and restart it! Should I need a new adaptor lead? Which plugs all 3 blocks in? An also while I'm on what lead do I need to bring back the use of the stalk radio options volume and channel switch?
Any help guys would be great!
The little yellow block is for the display where it shows the time and temperature etc on the dash, it is a pain to get this working once you have installed a new head unit!
Dont worry about the yellow block. That will be for the display and steering wheel controls.
The saving settings is normally because it is not getting the permanent live and needs the yellow and red wires swapping over in the loom behind the stereo
Thanks guys how do I go about getting the liitle block connected back up for the use of the display and stalk options?
I know it is possible for you to buy an adaptor that will allow you to use your stalk controls again either online or through Halfords etc, but as far as the lcd dash display goes, i dont think it is possible as most aftermarket/non-standard headunits will not be designed for this feature.
Cheers boss all I need to do now then is swap the two cables over red and yellow for perm live from battery to store channels
