Identifying 197 cams
  172, Tiguan
Is there a sure fire way to tell the difference between 172 and 197 cams?
I just want to check the cams I've got are actually from a 197.
The numbers I can make out are (though its really hard to read them):
Exhaust:
F4r r194
243 23h23
Inlet:
F4r a 318
E06 11h45
​Cheers
NorthloopCup
Offer them up to a set of 172 cams - You'll visibly see the differences in the lobes. The 197 cams have longer duration and they're also more advanced from what I remember.
  DON'T SEND ME PM'S!!
197 cams should have a timing wheel (4 teeth) on the inlet cam.
I've got a pair I bought that someone has removed the timing wheel so it's useless for what i wanted (actually going in a 197)
  172, Tiguan
I know this is a terrible picture, but the thing towards the right hand side?
I need to remove that then? I know thats a stupid question, i've not paid much attention recently.
  172, Tiguan
Cheers Dan.
I've got a rocker cover leak and these, along with some Megane injectors and a map, will clearly fix it.
  172, Tiguan
Sadly these are still sat in the boxes. I need to buy another timing horseshoe and get it bent.
I'll do you a part ex on some Pipers if you want, could do with a second set to get reprofiled as exchange units for the 197, and you'd see more noticable gains
  Clio 172 182 197 200
John. Sorry ive not replied but phone is acting. You can borrow the tools when I come and help.. Sunday mornning ok?
