Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Only thing I have done is jack the car up to fit a back box. Started car while still of the ground to check exhaust seal - all fine.
Got it back on the ground and started it, idle really high and hunting about
Solved, air leak between upper and lower manifolds. Caused by some MAD dress up bolts. They are too long even with washers so when you tighten then up they press on lower manifold
