inducation kit
  Renault clio 1.2 16valve
I was thinking of getting an induction kit for my 1.2 16v clio 54 plate but dont now whether to, does it make much differnce or not and if so which is the best on to get cheers
  Vectra 1.9 CDTi SRi 150
Did mine for looks only...no improvement...worse if anything.
Martin_172
open filter draws in hot air reducing engine power, closed/sealed filter gives slightly better throttle response, V.Small probably unnoticeable power gain, same goes for a panel filter in the standard air box, but going that route you dont get the noise that an open or closed filter gives.
if you use a relocated kit like the pic above you will loose torque due to the fact that the inlet tract is far too long, i had one and got quite a large torque increase going to a pannel filter! Relocation kit is a good idea in theory but just doesnt suit the engine.
