renault clio 182
I purchased a 182 clio on a 04 plate with a missfire previous owner had put new plugs ,leads ,coil pack and injectors .but still came up with fault so i traced the pink wire all the way back to the ecu on the way down from ecu besides the battery box loom had been chafing so fix chafed wires started it up fires on all 4 cylinders socif u do get a missfire fault please check feed to injectors first before apwnding a small fortune hope this will help someone.
