Injector size (cc) for single throttle body clio 172/182?
  182 inside
Does anyone know the recommended size in cc for the injectors on the F4R lump if fitted with larger single throttle body. Would picco 330cc injectors be recommended or get a fuel pressure regulator and up the current psi?
many thanks;)
  Ph1
Yeah, good up to 208 bhp so unless your in a very high state of tune running up to or over that or running TB's they'll be fine.
As for the larger TB size, seems to be split down the middle as to whether there's any performance gains to be had
  Lionel Richie
when i did the original conversion it turned out to be a pretty pointless affair for power, only squeezed a few bhp over a stock car
was better to drive, but an expensive conversion (if using the ETCC jenvey body)
just buy the kit from r-sport, job done
