Input shaft seal I think..
Car  Clio 1.5 dci
Split a destroyed 129 gearbox and good 130 box to make a good box with the speedo drive off the 129 casing. However upon removal the bearing/race/seal in the 129casing where the clutch shaft comes through has destroyed itself. It's triangular in shape and had long rollers instead of ball bearings. What on earth is it called and where can you get one I've been searching for 2 days..... Any help much appreciated
Fletch
Input shaft front bearing mate. Different bearings in a 130 though to a 129 and I'm not sure they're interchangeable.
I've got part numbers if your struggling for the triangular bearing.
Here you go @Fletchyboy93
