Interior light on a 172
  RenaultSport 172
Ok guys. Just what on earth is under the panel with the interior light on in a 2003 172???
Since I've had my car there is an electric buzzing sound coming from under that panel. It comes on when you turn the ignition on. It doesnt matter whether the engine is running or not. I can press the panel upwards quite hard and it almost stops the sound but you can still hear it buzzing. How do I get the panel off and what on earth could be causing the buzzing sound?
Thanks for any help
Steve
J-J
You tried taking the light out and checking the wires? Could possibly be a dodgy wire, also check the bulb is in right :)
  e92 + E46 M3 + Cup
Its more than likely the climate control fan, can be noisy, may just be blocked up with dust causing the noise
  Clio200 EDC Lux
Yes correct the sensor for the climate control is in there (mine suffered the same thing) , do a search there is a video for replacing the fan inside.
  RenaultSport 172
Have disconnected it today. Will it cause any problems??
I'm assuming thats how the climate contol knows the inside temp?
  RenaultSport 172
It seems that heating don't work anymore though! Must be cos it can't tell what to do. Guess I will connect it back up in the winter
