Intermitent engine cut out problem
Car  clio mk2 1.4 16v extreme
My car is a 1.4 16V 05 plate, the engine is standard.
Sometimes when i start the car it dies strait away, it will do this until i give it some revs and hold the throttle open a little.
Other times is starts first time no problems, if its cold it will hold the revs higher etc as expected.
Also sometimes i will pull up at lights take the car out of gear and then the revs will drop and the car stalls. It will occasionally basically stall (all lights on on the dash) then rescue itself and the revs pick up and it's ok.
I have just had a second Renualt service done on the car, the car has 30,000 on the clock. apart from that it drives well, pulls well throguh all gears and has good accelleration.
2 ignition coils were replaced by renualt under warranty, then i replaced final 2.
Any ideas?
thanks
john
