Subframe and driveshafts mate. Not 100% sure if ff ph2 172's had the skinny ph1 track width though or not. Cups and 182's are the wider track though.
Hubs are all the same.
The phase 2 172 non cup has the same narrower track as the PH1. I know, as I swapped to 172 Cup wishbones on mine, from standard wishbones. It is a 10mm track width difference in total.
As said, other than the wishbones, all the rest is the same. I know, because when I swapped the wishbones, I didn't need to swap / change anything else.
The arb is different as well? the bushes are different on a phase 1 compared to a phase 2 23mm vs 25mm. Ive managed to get a complete phase 1 setup so going to use all of that
