Is it possible to change the abs to read 44 tooth and instead of 26
GrahamS
Just done my widetrack conversion. It was funny that my car registered me as going 70 when I was doing just under 40. Obviously the abs is set up for 26 tooth rings but the sport gear has 44.
I've got a clone clip. Can I change a setting in the abs module to read this higher number of abs teeth so I get an accurate reading?
  clio dci , ren8
Never tried but will be in ABS config if its possible , just fit the 26 tooth rings or get some new of ebay
Dr HMS Derv Destroyer
  MK1DTi/MK2DCI/ASTRA
As matt said, change the rings, don't go faffing with settings, specially on clones, I got a lucky escape coding injectors with a clone...l
