Is this battery any use?
Car  265
Im getting a new smaller battery in order to fit my induction kit. My current one is a bit too long. The regular Clio 182 battery is meant to be an 063 but im not sure about the required CCA amperage.
The one i have at the moment has these specs:
075
CCA 570 amps
AH 60 amps
The battery the garage offered me to try tonight is this:
Is this any use to me?
it should be fine but you will probs find dimming when you have an extra loud i personally would upgrade to a heavy duty battery
Ah i see. Didnt realise that could be a problem. Ill stick in in tomorrow morning and see if the it has enough power to turn the engine over anyway
keep your other battery near you though mate as if its cold were you live the batteries wont be at their best in these cold conditions
So the battery is in along with the new induction kit. Its working fine so far. Doesnt seem to hesitate on startup or anything.
Going to take it for a drive shortly. Ill be keeping the other battery in the boot just in case.
