Is this too far gone
1985michael182
182 is the lower shaft
172 is the upper
RustyMojo
Bon Jovi Officianado
What is it?
GrahamS
I know you'll think it's madness but I highly recommend getting one of these
The diagnostic ability it will give you is superior to a generic code reader. I've had mine for 5 or so years now and it's paid for it's self so many times.
You'll be able to interact with the ABS module and ESP to be able to determine if the values it's seeing are correct.
04-182
  AB Clio 182
Yeah, I've been looking at them. there is a car tuning company about half mile from my house so was hoping they might do me a solid. You need a windows 7 laptop aswell to use these dont you?
GrahamS
Indeed you do, can't beat the genuine diagnostic package for things like this. Any laptop with the ability to run a 32bit OS will be OK so XP > Windows 7 is good. I have an ancient laptop specifically for this. Super slow and the battery doesn't work but I only use it for car diagnostics so I can tolerate it.
04-182
  AB Clio 182
spent a small fortune lately so this will have to go on a wish list i think. Spent not far off the price of the car on parts and tools so far. Atleast tools i can re-use.
04-182
  AB Clio 182
On a twist / different note. I had a BG 182 and now have an Arctic Blue one (3/4). Ultimately i would like a nice RB 182, turini wheels and trendline seats. maybe wishing on getting hens teeth or rocking horse %^& but thats my aim i think.
04-182
  AB Clio 182
Ok so a little progress. Managed to get the hubs off both sides. As with everything so far lol I had the odd issue and found the odd extra bit.
One disc screw i had to drill out another i just had to hammer a bigger hex bit into to get out.
The top Camber adjust bolts were a right pain until i worked out if i slowly turn then tap then turn then tap until its lined up they come out easy.
Anyway they're both off. One CV boot looks on its last legs and weirdly the back of one hub looks like its been ground. Discs and pads have got next to no wear on them so must have been fitted not long before being parked up. oh. and might be my eyes but i think one of the track rod ends might be bent aswell.
well thats is so far. ABS sensor is on its way (1st one was wrong).
botfch
  Clio 182
Ah balls didn't realise these only work with 32 bit I'm waiting on one from China land.
Any idea if they can be updated to work with 64 bit I see people on ebay selling the v195 software for £4.
04-182
  AB Clio 182
From what i've read they can't. Lots of cheap laptops with win 7 on on ebay though. seen a few for like £25
botfch
  Clio 182
I can virtual machine it I imagine, will give updating it a go worth a shot for £4.
lemonnobby
To the op you really need to find out if this car has cup pack or not makes or life easy when ordering parts
04-182
  AB Clio 182
Its a 182 with both cup packs. 60mm front strut spacing 15mm abs rings etc. previous owner(s) have just been total cabbages.
04-182
  AB Clio 182
You can get the radio code from the serial on the headunit if you are without (There used to be a page on here for it too)
Bilt Hamber Deox C is very good if you want to shift some of that rust, I done my calipers with it and they came out like new (Stick the part into a container and pour a hot kettle in with the Deox and leave it overnight)
Sounds like you have one hell of a revival on your hands, best of luck.
Can i soak my Hubs in this stuff without it damaging the bearings?
04-182
  AB Clio 182
Progress. Hubs next.
Louis
I Love Ed Sheeran
Is that abs ring chamfered on both sides?
If it's not, I have a feeling that might be on the wrong way round...
I didnt pay any attention when I did mine 3 years ago haha. Never had a light on, I'm sure they're identical side to side
04-182
  AB Clio 182
Yeah. Both sides. I got two in case I bodged it up.
04-182
  AB Clio 182
The ones I have came with a bigger chamfer on one side so that they sit right in on the shaft.
Can see it sitting out a bit here.
I thought that but the other side is the same. Slight overhang. It’s upto the shoulder though. All a learning curve for me.
  LY 220 Trophy+IB PH1
Yeah the Deox C is pretty harmless to anything but rust, but I would put bearings in too - they are an absolute nightmare to get out though (Had to use acetylene and a press on mine)
Looks like you have upper camber bolts too
04-182
  AB Clio 182
yeah its got camber bolts but i'm not planning on putting them back in. it was sitting low when when i got it but i'm putting all new suspension in and lifting it abit from where is currently is.
Will give the Deox a go. Its in the post. Will look at new bearings after lock down if i need some. Hubs might end up being scrap yet. Theyre heavily rusted.
04-182
  AB Clio 182
Good spot. I triple checked it. It was slightly proud where you’d ringed. Thank you. Tapped it in a little. All good now. 👍
