Issues in cornering help!!!
Car  Clio 197
My clio 172 is pulling when going around right corners.
Had the track rod ends done and the wheel alignment done.
I was thinking it might be the control arm on the NS. Had the same problem years ago with my 197 sure it was the control arm.
Any help would be nice.
Go to France and see if you have the same problem on left handers?
Something to do with the camber of the road _--_ .
Did you get this sorted yet Dan?
Have the same issue - have rebuilt calipers, checked rack bushes and colum - everything's tight as a drum.
TPs are all the samea dn have had laser alignment.
Still slight pull on progressive right handers - made worse if its bumpy.
Out of ideas.
Have you checked rear suspension? Or to be more precise rear dampers? When I bought my first 172 the rears were knackered, changing them made a huge improvement to the handling
