I've solved my clutch noise!
DomP182
Car  ph1 172, Arctic182
Quite simply the brake fluid reservoir touching the engine block when pulling off. I've had this for near two years and always thought it was a dodgy release bearing until I made it worse doing a brake overhaul causing the reservoir to touch constantly. Such a simple fix just wish i had noticed it two years ago
Hard to explain but it all makes sense now because it had a horrible feel through the pedal as well. I suppose it was a grind but it is well worth checking if you get it as is a free and easy fix just to post the reservoir back onto its seal/gasket
