Jacking point for 172
Car  1995 Mondeo Speed Machine
Wheres the best place to lift the front corner up using a trolley jack? Im reluctant to use the standard point on the sill as Im concerned about damaging it. Also, where should I position an axle stand once the car is up? I can see a couple of points under the car which I think should be suitable but it would be good to get the opinion of someone who has done this before.
Ive taken a quick under car pic if it will help anyone to explain where I should jack it up! The wheel on the far side is the offside front just to give you an idea of perspective.
http://erc.qmuc.ac.uk/cliosport/gallery/full/1103381524__jack.jpghttp://erc.qmuc.ac.uk/cliosport/gallery/full/1103381524__jack.jpg
Hopefully the pic is clear enough
As always, any help would be much appreciated.
Rick
Anyone still got those pics? I need to jack up my Mk2 172 to get access to the underside of the gearbox.
Thanks,
Gareth
Thanks Rick - 5 minute response :)...
Do you spread the load with wood or something? I have some old carpet taped over the saddle of my TJ (to protect the powder-coated chassis rails on my 7) - is that good enough?
Just thinking that the V in my axle stands prob isnt wide enough to straddle that section. Do you just sit it on?
I sometimes use a block of wood between the trolley jack and the car but quite a few times Ive just used the jack straight onto it. The axle stands have never been a problem for me, as long as you get them lined up directly under the beam I cant see that youll have a problem.
Quote: Originally posted by CHRIS172CUP on 31 August 2005
I cant get my trolley jack that far in!
Mine neither so I just used the sill jacking points and they didnt bend (this time).
