Juddering under acceleration?!
Car  Clio campus
Sorry my first post is a problem on here, but my girlfriend drives a 1.2 clio campus it's an 06 plate
Basically I'm hoping people on the forum are as helpful as mx5nutz *fingers crossed*
It seemed to have devolved this problem over night, I used it to get to work this morning and the exhaust was.. A constant pop? She's got a full exhaust system on it which did tend to pop when you change gear which was never an issue, but constantly now the zorst is popping, sputtering?! When you accelerate it's judders viscously, the gear stick goes on a mad one.. If you keep it juddering it then levels out back to normal but as soon as you give it more throttle its starts again
Any advice would be great!
Cheers Luke
Checked plugs today by having car running, and pulling each one as I go, replaced 4th but to no avail, how could I check the coil pack?
Coil pack is a common problem with these! Is your coil pack all one (with the leads connected) or can you disconnect the leads from the pack?
I know they revised the engine circa 2005 but unsure if they changed this.
