Just got a 182...
  Black 182 FF
...and while I'm over the moon with it - can someone tell me what the craic is with spare wheel, as it doesn't seem to have a well for one and the exhaust is where the under tray would normally be, hence I haven't got one.
Someone enlighten me please :S
  Black Gold 182 FF
Hello, yeah there is no spare wheel and nowhere to put one- the exhaust takes up the space where the wheel well is on other clio's. You just get the spray cans to fix it. I was thinking of getting a cheap wheel and putting it in the boot.
  Black 182 FF
Have to have a look and see if there's one in there.
But yeah, a spare just incase would be a good idea.
There's meant to be two cans of tyre foam (Halfords stuff will do) in a pouch, originally under the passenger seat IIRC.
  Arctic 182FF + Escort Van
No spare wheel. Hope you have breakdown cover as i wouldnt trust the foam to get you home, especially if its sidewall damage as the guys have said
SC03OTT
  Golf GTI
Spray foam is crap, any sidewall damage and it doesn't work.
Any sidewall damage and your tyre is fecked regardless though or even if there's companies who will bodge the tyre it's not worth doing.
i think the point he was making is that you wont be able to use the tyre foam if you have a puncture, if the side wall is damaged. i can only assume this is because the foam will not form a good enough seal?
ForceIndia
  Gentlemans spec 200
Exactly. Get sidewall damage and you're stranded.
Si
  RS Clio 172
spare wheels are rubbish anyway. i removed mine from my 106 long ago. tyre weld is the key. a lot of manufacturers are ditching the spare now, can't be too much wrong with it if they're doing it.
also think of the weight saving!!!
ForceIndia
  Gentlemans spec 200
Manufacturers are dumping the spare for economy (mpg) and cost reasons, and in some cases due to runflats. As said before, tyre weld does f all if you get sidewall damage, my spare gets me home, the fella's with tyre weld are stuck at the roadside.
  Mini Cooper S sport
Tyre Foam also equals a new tyre as once the foams sprayed in thats it
Cant they just wash it out:S i have the same problem with no spare and assumed you could reuse your tyre:S :S
Nope, it's buggered once it's been filled with foam.
TBH I'd never go without a spare wheel again. Once got a huge puncture on holiday in Cornwall and couldn't use the foam due to the size of the hole in the tyre. It was a nightmare involving hours of waiting, the AA and a night without my car cos it was at a garage while I waited for a new tyre to be ordered.
  Black 182 FF
Depends. Tyre foam may help seal a sidewall (depending on the damage/split - as it may only be a small puncture and not a total rupture), but using it as anything but a 'get you home' tyre would be idiotic.
It totally depends on what's gone through it or caused the damage - if something equally as big goes through the middle of the tyre it's the same story, you wont seal that without a plug, if you do at all.
Sidewalls usually take the brunt off kerbs and stuff though, hence people think they're weaker and won't seal because they often split, rather than get punctures.
SC03OTT
  Golf GTI
even if you were doing 80mph, i think a burst tyre would be the least of your worries...
  Ph1
How often do you have a flat tyre ??
Iv only had 3 in total since i started drivng 15 years ago and 2 of those were in one hit due to going over a piece of wood.
You might say its risky not having a spare but then how many folk run about with zero break down cover and thats 10 million times worse !!
