K tec brakes
Hi ppl i have a 172 cup with standard brakes which i am in need of upgrading straight away so was thinking of k tec drilled discs on the rear whilst up front come in the way of drilled and vented aswell as their kevlar pads and stainless steel hoses all round so if any one has heard good/bad things about them i would appriciate it. Many thanks.
As said, don't waste money on the rears, they are good enough. I have the k-tec kevlars on the front and they are basically oem replacement pads. No noticeable improvement over the oem pads but definately less brake dust. If the front discs are worn then just get the vented Brembo discs to replace them from yozzasport. Don't waste your money on drilled. When my front pads need replacing I'll probably get some greenstuff pads plus the SS brake lines from Fred which are probably all you need for the road. A more exotic pad will be needed for track use though.
