K-Tec Exhaust, Sitting low
I just got myself a K-tec twin 3" cat back exhaust. Got it fitted, and noticed it sits quite a bit down from the bottom of the bumper. Anyone else had this problem, if so, just a case of a bit of cutting welding or bending the rear bracket holding the rear box??. Car is also lowered 50mm and hits off the axle when going over bumps. Cheers for any info
Fraser
My twin 3" - fitted by K-Tec themselves - has a gap of about a 0.8 cm (depth of a little finger) between the bottom of the bumper and the top of the pipes. Think they used some sort of stainless strap around the back box which seemed to allow a lot of adjustment!?
you need to twist the centre section so it sits really high against the car (obviously not touching!!!!)
then piss about with the rear bracket/strap
