K-Tec/FK Racing Coilover Suspension Kit - Fitting Guide Needed!!!
How much negative camber is on the front now? Is it very noticable on the front?
Very noticeable on both sides mate!! Its worrying me.
Spoke to a friend of mine and he's got a habbit of overexaggerating and he basically said that I have bent my camber and its going to cost me £700! Full of sh*t...right?
If I put my old shocks / springs on, everything should correct back to normal right?
Negative camber? Dunno how to measure that seeing as I have just today found out that there is something called Camber! LOL
actually i do have slight camber, not much though... might be the reason why my cars vibrates like f**k after 80-100... other than that at normal speeds its fine..
FLOL!!! Thats possibly the best thing I've ever read. You're mate is officially a r****d. LOL! Amazing.
Yes going back to standard suspension will sort it. It seems very strange because as far as I know even with them lowered to the bottom setting it still shouldn't effect the camber enough to cause a major problem. It'll give you negative camber yes but nothing major major. Tbh theres only so much I can do/say without seeing them anyway, primarily i'd be tempted to get them off and get the adjusters (hopefully) freed off before going any further.
i have a bit of camber not very much though, but i like it lol its like / \ but obvioulsy not that much of an angle! anyway PROBLEM!
ive adjusted the coils and it seems when they reach a certain point they seize up! it gets really hard to turn them... i want to lower my car at least another 20-30mm... how can i solve this problem???
Adjusted the camber on the FK shocks...
SORTED!!
wILL UPDATE WHEN i GET IN FROM WORK!!! oops caps!
