It’s been an eventful week for AWS Racing. The highs and lows of Donington seem a long time ago now. Anyway, after a dash down to see Fred at BTM on Sunday (thanks for the door and wings Fred), the Clio was loaded onto the jig on Monday afternoon. Once we Stuart got the door open, the full extent of the damage became apparent. The outer sill was flattened against the inner sill which had also been pushed in. The A pillar was approx. ¾ inch in and the B pillar was also across and back. Stuart has to cut a hole in the sill and weld a plate onto the inner, before pulling both with the jig to bring them back to where they should be. Once back into shape, the plate was cut off the sill and the hole welded up.
[/IMG]
Heres the before I posted a few days ago:
[/IMG]
And the afters:
[/IMG]
[/IMG]
As you can see, the side skirt will never be the same again, but will be replaced over the winter, along with the sill.
The other issue we had with the car was all the gravel it collected. We started and ran the car briefly at Donington, but after the noises it made shut it off again. It had been mentioned that gravel can get into the bell housing through a small gap between the engine and gearbox. This in turn could, and has in the past, jammed the crank while the engine is running and thrown the timing, causing valves to meet pistons! The bell housing has been checked for gravel and some has been removed. Stuart also checked the cam timing with the Renault tool and turned the engine over with the plugs out just to be sure. After all that was done, the engine was started. Sounds as sweet as before.
Now I’m just waiting for the care package I ordered from K-Tec today to arrive and with a couple more days, will be ready to go again.
Many thanks to Stuart for putting in the hours to get us back up and running again so quickly.
