Kanglio 182 Build Thread
  Kangoo
this write up has been so handy so far, when it comes to the door looms it says you moved the looms from the clio into the kangoo and the connectors were the same, mine has different connectors at the door and the switches for the windows are different, managed to get a couple of door looms out of a scrap kangoo which have the correct door connector but obviously use the older style connectors for the window switches, dont suppose you remember any more on this or did you use the clio window switches?
Hi, Yeah just used the clio switches.
The door lock solenoids were a direct fit.
  Kangoo
Ahh that makes sense, thanks! i was starting to tear my hair out going through wiring diagrams with none of it matching up! did you just cut the plastic switch panels to fit the switches?
