ChrisPearson fiesta 1.25 Jun 22, 2009 #4 Does it only work from a short distance?If so mines the same i tried changing the key fob battery and it made no difference.
JayK89 1.4 16V Mk2 Ph2 Jun 22, 2009 #6 ChrisPearson said: Does it only work from a short distance?If so mines the same i tried changing the key fob battery and it made no difference. Click to expand... it doesnt matter how far away from the car i am, sometimes it just doesnt work and i have to press it loads of times before it opens/closes
Mark One ValverInBits Jun 22, 2009 #9 take it apart and be very carefull fixing it. It will cost you upwards of £140 to get another.
K1NGY Fabia VRS Jun 22, 2009 #10 How do u take the key apart / put it back together as mine does the same
TOGUSA CLIO Iceberg 172 Jun 22, 2009 #11 if you take the battery out dose it have to be recoded back to the car? dose it reset it?
ChrisPearson fiesta 1.25 Jun 23, 2009 #12 Not if you replace it quickly.If its left with no battery for a certain amount of time it needs recoding iirc.
