Keyless entry/ ignition
  RenaultSport 182
Hello
I’ve just bought a clio RS200 on a 62 plate with keyless entry. When I turn the engine off how do I also turn the ignition off? I know the ignition goes off when I lock the car but if I want to vacuum/clean the inside of the car I don’t want the ignition on the whole time. I really do miss a simple key...
Thanks in advance.
Mbeau
  Clio 172
I have keyless entry and start on my rs 250. Unless you push the start button on entry the ignition is not on? It does not turn the ignition on without the start button being pushed.
  RenaultSport 182
When I open the car the red exclaimation symbol is lit up on the display, there’s power to the fan, radio etc so this is my definition of ignition on. The mileage display and ‘press brake to start’ is also lit up. On my old 182 all this only happened with the key is in and ingition turned on...
  RenaultSport 182
To clarify. This full description of what’s lit up is when I get in the car and don’t touch the start button.
