ktec braided hoses - only two copper washers?
As per title. Should there not be four copper washers with the ktec 172/182 braided hose kit? I've contacted the guys by email anyway, but thought I'd ask here in case you do only need two washers.
my box only has 2 in it mate. This is the second lot though. Check that with your you have 2 lots of 2 the same. I had an odd one in my first lot :(
Friday afternoon assembly FTL :(
Slightly confused with that. I have one box, with 4 hoses and a plastic bag which contains 2 copper washers.
I'll be doing my discs and pads tomorrow, then probably the hoses and fluid on Monday. I have the use of a pit, which should make the rear hoses a doddle :)
If that's the crush washers then yeah, you only have 2 as explained on the Goodridge instructions :)
I did my front discs & pads today, will do the lines & fluid next day I'm off work :)
