Laptop Upgrade
Car  Punto/Clio GTT
moms got a s**t slow laptop, its got like 98mb ram with a 1300mhz processor.
it runs stupidly slow.
im sure the procesor i can work with, but i really think it needs more ram.
how do i change ram in a laptop, where is it and does it basically look like desktop ram?
is there a limit i can put in the laptop or do i need to know motherboard details or something?
cheers
cheers
Only ever owned 1 laptop, and that was a good few years ago, but it had a small panel on the bottom that you can unscrew to add more/replace memory.
Think the limit will be down to what the motherboard will support.
Looks similar to desktop ram, but smaller:
http://images.google.co.uk/images?gbv=2&svnum=10&hl=en&safe=off&q=laptop+memory&btnG=Search+Images
how can i find out how much the laptop can handle?
or shall i just throw aq cheap 512 in it off ebay.
are all laptom rams same size, pins etc
Laptop ram is nothing like desktop ram. There should be a slot on the bottom of the laptop (probably need a screwdriver) have a look in to see if you've got any available slots.
I'd take a quick look around the net and try find some info on laptop memory and about the different kinds, and if that doesn't bring anythin up, then I'd personally gamble it with a 512 stick as you said.
Installing is easy enough: http://www.computermemoryupgrade.net/installing-laptop-memory.html
Not to sure about the size and pins, but get her laptop and take a look at the current memory that is in in and count the pins or something, or just find some that looks like it :p:D
