Laptop upgrade
Cookson
  Mk1 Audi TT 3.2 V6
So the laptop at home is getting old as f**k and really slow. Toshiba Satellite L300. I think it was bought in 2009.
The battery is on it's last legs and the specs are a whopping 2gb of RAM and a 160gb hard drive. It's still running Windows Vista
Rather than splurge out on a new one, I wondered whether I could just chuck a couple of upgrades in. A new battery is about £15. Maybe up the RAM to 4gb and put a SSD in at say 500gb? It literally gets used for Sandra surfing the web and downloading virus' whilst viewing spiritial web pages etc. We don't really store films and music on it.
@YorkshireKyle you're an IT nerd aren't you?
YorkshireKyle
And your RAM might even be DDR2 SODIMM which is definitely less than £5 for a 4GB stick
It's just whether your CPU and mobo will hack it
Cookson
  Mk1 Audi TT 3.2 V6
How do I find out what it's running? The sticker on the front says Intel Celeron
JamesBryan
Task manager will tell you.
and if you click on Memory it'll tell you what RAM you have.
Cookson
  Mk1 Audi TT 3.2 V6
Update on this, I was going to sort the laptop and decided the one from Perrinho would probably be better. However, due to the apocalypse, I assume he has been mad busy. So I've set up my older tower to work from home and brought a spare screen home from work. At first, it would not even recognize the screen despite being plugged in (one DVI, one VGA), and I put that down to the crappy onboard graphics card. I installed the updated driver for it and it started working and sees both screens. Awesome.
However, after around an hour of working remotely through the VPN at work and having youtube on the other screen, it does this s**t.
I guess it's being overloaded then and I need a better graphics card in there? Can anyone recommend anything that isn't going to bust the bank? I assume it goes in the blue slot?
May as well chuck some more DDR3 in there whilst I have the cover off eh?
@YorkshireKyle @JamesBryan
YorkshireKyle
If you can get some more DDR3 then get some mate. Make sure it matches the size speed of the other as DIMM's need to be matched
I might have a a few old GPU's about that might work mate nothing special but will easily push out to a few screens and have 1 HDMI output
Cookson
  Mk1 Audi TT 3.2 V6
Whats a GPU?
YorkshireKyle
I'll dig one em out and then post em to you if you want mate. I've got no use for em, they're old but would probably still help you out without spending more money
Darren S
When you take the side off next time, just check on the CPU cooler itself - that big fat Intel thing with the fan on it the picture. Just give it a quick blow (ideally outside) to get rid of any residual dust build up - or with an air compressor ideally. The stock Intel coolers are paired with the CPUs themselves with about 0.00001% margin for overheating - by that, they do the job, just.
Any dust that builds up over time in between those cooling vanes, restricts airflow and can make the CPU overheat and shutdown.
