Two many pies slows you down. Fact. My car is rapid yo. But i am a fat c*nt.
:lolup:
Dont agree nancy boy (BenP)! I will have to take my own lines of investigation I think!!
Paul, you need to have sex.
Ever go bowling? Compare an 8 pound bowling ball to a 16 pound bowling ball. The 8 pounder is easier to accelerate (from the stopped position to you throwing the ball at higher speed) and easier to direct (aim). Your arm also gets less tired with the 8 pound ball. The drawback is that the ball loses more speed toward the end of the bowling lane, and may not knock down as many pins as you want. You also have to be more careful with controlling the direction of the ball, since it's easier to fling out the wrong way if your arm twitches or something The 16 pound bowling ball is harder to accelerate and harder to direct, but it carries more speed at the end of the bowling lane because of its higher mass (and resulting higher inertia). It knocks more pins down. It's also harder to send the ball careening into someone else's bowling lane, because it's harder for your arm to suddenly jerk it to the side.
Now relate this analogy to a car... the pins at the end represent your car's weight/mass, the bowling ball is the flywheel, and your arm is the engine. The lighter flywheel will be easier to accelerate and decelerate- so you'll have quicker starts, faster acceleration because the flywheel has less inertia to overcome, and quicker shifts because the revs drop faster when you let off the throttle. The downside is that you have to control the flywheel more, since the direction (speed of rotation) varies that much more. This is why people say that an "8 pound flywheel isn't good for a daily driver". I don't have any problem driving with mine. The heavier flywheel has higher inertia than the lighter one, so it will start your car from a stop more easily (knock down more pins), but it will hurt you everywhere else. It takes more force/power to accelerate (overcoming more inertia), doesn't allow you to shift as quickly (revs don't drop fast enough), but it is easier to drive because the speed of rotation doesn't change as rapidly as the lighter flywheel. Small changes in your throttle position don't change the revs as much, because the power blips are just soaked up in the heavier flywheel. This is why people might think that "a lighter flywheel takes more gas while cruising", because that lighter flywheel takes more attention at the gas pedal than the heavier one to maintain speed. The lighter flywheel will give you better gas mileage.. ever push that 8 pound bowling ball on the ground at a constant speed? Now try the 16 pounder- which one takes more energy to push? The 16 pounder. It's the same as the flywheel.
Do you lose torque with the lighter flywheel? Yes and no. You lose torque to start the car moving, since less energy is stored in the flywheel- so you have to apply more torque from the engine. On the other hand, you use less torque to overcome the inertia of the flywheel while accelerating and decelerating, so you can use the torque from your engine more effectively. You don't lose any torque when going to a lighter flywheel- you just change the source and application of torque in your car's drivetrain.
So...
Light flywheel: better acceleration, better mileage, takes more skill to drive
Heavy flywheel: worse acceleration, lower mileage, takes less skill to drive
back in your box see you next week then. after you write a entry on wiki !
I found this thats quite interesting (for anyone that cares about the actual topic lol)
So...
Ben get your boyfriend to have a quick peek I'm sure he can give a quick yay or nay answer on this.
172bagss - I didnt mean Gray I meant the other Ben!
I dont think you'd lose torque, but you certainly wont gain any. higher revving engines suffer with a lighter flywheel. FACT.
