Looking into a map
Car  Clio sport 182
Looking into Geting my 182 mapped, it's running a full cobra system from a previous owner. Looking for some advice on what I should get before the map
Thanks, leigh
Got air filter already on and belts been done Will my standard ecu be ok ?
Yes mate, have a search for the hand held rs tuner, you buy the devise and then upload the map via your laptop yourself, its meant to be one of the best mods you can do for the money, you can pick up a second hand one off here for £110 but you will need to pay for an unlock code.
Excellent thank u
No.
it just locks yours to only be mapped by the rstuner. Which means if you decide to get cams or an jms intake you won't be able to get it custom mapped on a dyno.
you would need to replace the ecu if you decided to do that later.
but if you never plan to then the rstuner is fine and the map makes the car behave nicely.
No.
How much more power can U run from the rstunner
