Rob
		have you measured beneath the subframe before and after? that doesn't look like a 60 mm drop on the front tbh.
GAZ said that their coilover kit which I have could go 60 or more mm lower but in real life if I tried to go 60 mm lower the car would be standing on the bump stops on the front leaving no shock travel at all. Maybe some of you guys are measuring the drop in other ways, I'm always taking measures under the subframe
That is a drop with no measurements, that's a drop with 60mm apex springs. Simple.
When measured it was near enough correct, sack all this subframe crap, if you measure to the highest point of the arch from the floor, you get (and can see) pretty much a 2" difference. Which is 60mm.
