Lowered. Will springs be ok?
Just lowered the g/f's car 35mm.
The rear springs being shorter don't seat properly unless there's pressure on them ie sat down normal. When you jack the car up the come lose-ish.
They are sat on the rubber cups fine when the car is down on the road and they don't move, I just want to check that this is correct as there is nothing holding them in apart from the weight of the car.
cheers.
Ok cool, thought it was right but just wanted to check for saftey's sake obviously. Drives fine, apart from a whirring noise from the front nearside. Like a wheel bearing, but I think it only started since lowering but can't be sure. Maybe the change in camber has meant more pressure on it or something.
