Lowering my 172
Car  Clio 172 ph2
hi guys im lowering my 2002 172 i have bought a set of 60mm lowering springs to put on untill i can afford coilovers,
will there be any issues i should be aware of when fitting them and will i have any problems after such as . . . .
  • driveshafts
  • CV joints
  • rubbing (standard 16's)
  • etc
cheers for all your help,
sam
Won't rub at 60mm with standard 16's. My question for you si where did you get 60mm springs from? :S ive never seen springs for a sport lower than 40mm unless theyre custom made
You should replace your dampers with 60mm springs although many favour the shut your eyes, hands over ears and la la la approach.
