lowering problem help please!!
Car  clio cup172
hey ive just lowered my 172 cup with apex 40 mm springs, when fitting the springs i tightened the top nut as much as i cud without the shaft of the shock turning, refitted the shocks and put the top mounts on as tight as i cud ,today i lifted the bonnet to find that there is now a gap between the bottom of the top mounts and where they should lie flush on the bodywork of over 1 cm . is this normal as i cant get them any tighter? i also have a lot of vibration coming through the steering wheel??can anyone help please, thanks
they DO NOT touch the bodywork, hand tight is fine (MAKE SURE YOU HAVEN'T ROTATED THE SPRINGS OUT OF THE SHOCKS)
get a mate to turn the steering while you look at them, you'll soon discover why they don't touch the body
i have checked the springs and they are sitting fine , any ideas why im getting so much vibration , could the tracking need done since lowering??
vibration sounds wrong, on the 100+ clios i've done none of them have ever vibrated, you've gone wrong somewhere
just the alignment with just springs, but leave it a month or to to bed in
i have just had the car jacked up and the passenger side wheel bearing is on its way cud this cause the vibration???
i have found the problem i think , i removed the tom mount to find thet the bearing has cracked and is allowing the shock to move, could this make the steering wonky and cause vibrating, also can i buy a bearing on its own or do i need to buy a whole topmount???
it fits under the rubber part it was seperate when i took it appart, anyone know where i can a replacement top mount cheap for a 172 cup?
