Lumpy Idle - Denso plugs
Car  Phase 2 172 Cup
got the car serviced lately, including timing belt, aux belt, water pump
the idle seems to be abit more lumpy than before
the mechanic recommended Denso Irridium plugs, and he put them in
would this cause it to be lumpy and run worse than before??
Chris
Did he use the proper tools for timing up the belts/cams?
What was the gap on the plugs before he fitted them?
Locking tools are important as so many have been timed up incorrectly before, although they usually feel slower when they have been.
Change them for the the proper NGK PFR6E-10s if you want to see if they make any difference.
yes all the correct renault tools were used
engine seems to be times correctly, its pulling from low revs
vvt comes in at the same point, and revs to the same point
ive a spare set of ngk pfr's chris if you wanted to try and see if that makes a difference
