KitsonRis
		I want to run a battery isolator on the dash board so need to run some wires from the engine bay to the inside. I’m already using the hole by the bonnet release for my external radiator fan switch (which appears to be the first place most suggest plus I don’t think it’s big enough).
Before I go taking the entire dash out, I assume the best bet is to remove the dash to open up some more space to get a drill through? Will need to be big enough for battery cable and while I’m at it I might run some more wires through for oil temp/pressure gauge. Or is there another hole I could use, I can’t see any.
