Making An active sub removable
Car  Mazda Mx5 1.8 Mk2
Hey,
Wondering if some of the audio guys could help me?
Looking at getting an active sub and running it of the rca leads from the back of my headunit.
Only problem is i would like to be able to remove the sub when im not using it or need to put something large in the boot, is there a simple way of doing this because im going to be left with a live 12v wire in the boot?
Chris
Hey,
I'd rather get an 10" or something that kind of size for the boot, was thinking about getting something like an underseat one, but if i get a cheapish active one for the boot now, when it comes to doing a proper install it will make things a bit easier because the wires will already be there!
Thanks though!
Chris
iirc vibe do a plug with the earth and live wired to it, so you end up with a plug and not a live 12v bare wire! i will have a quick search for you 1 sec
What about taking the fuse out of the power cable? Or will that not be sufficient?
Hey
Well any other methods creating the same effect are much apreicated because i would have to agree, £13 does seem a bit extreme for what it is!
Thanks Chris
